FoamyDM
Building Fool-Flying Noob
I built something the other night and I realized I haven't sat down to build in a long while. Part of it is I'm trying to goad myself into cleaning and setting up my shop, and the other part is to finish the few planes that I am READY to fly. but I want landing gear first. However, I will be scratch building the HRC Seven likely just the skins tonight.
What I miss is CADD - and designing the great ideas rolling around. but I must admit there have been a NUMBER of GREAT looking designs floating around.
Flyingshark
Started my second Mini FT Flyer today!
I got the rear fuse, power pod and tail section done. Wing, electronics and control linkages will happen tomorrow.
(Build thread is in my signature.)
Tench745
Oh yeah, thanks squirrely. its looking better. And my mouse isn't in the way either.
I also moved up the wing
Looks a bit like a corsair, but the tail seems huge. You're right that something doesn't seem right about it. I had to play with it a bit myself to figure out what seemed off. I think it's the juxtaposition of graceful curves with sharp lines and nothing tying them together.
I shortened the tail a smidge, put a bit of a transition from the turtledeck into the fin and added some curve to the tip of the tail. I also made the fuselage follow a nice curve around the nose. Something still seemed a bit off, so I changed the wing incidence so that when this plane is flying along it will look a little less like it's trying to dive at the ground. If the wing incidence changes, you'll have to adjust the power pod and h-stab to match. I would also mount the power pod just a bit higher than you've drawn. Just my 2 cents, feel free to take or ignore any suggestions I've made.
Timmy
Looks good. For ease of construction I would lower the wing back down so the pod doesn't interfere with it
"drag" the whole rearend down a little to get nicer proposions. View attachment 179064
Thanks! I'll combine all your ideas into the final sketch. @leaded50 - nice catch with the "drag the tail down"
