I have almost finished the Tiny Cub.
The new XT30 connector has been soldered in place, ESC now all wired in and motor rotates the right way. Same with rudder and elevator both moving in the correct directions.
I did a quick CG check using the AR6210 receiver, which I was using for the testing and its almost spot on
. It could benefit from maybe a little nose weight
Not quite happy with the ESC position and battery lead location, so they need some relocating. I also need to do some touch up painting before it gets flown particularly where I had to fit a fillet to fill a gap behind the firewall.
Other than that she is done and ready to go again, I gave the motor a quick blast it should be enough to get it airborne and cruising around (its the old F size motor 2300kv). Actually looking forward to see if she behaves better now with the smaller motor.
