That doesn't look like the standard FT foam/paper hing.Few update pics of the F22 Mk2
View attachment 199834 View attachment 199831 View attachment 199832 View attachment 199833 View attachment 199835
I have made some of my own modifications as I went along, to improve on the original design.That doesn't look like the standard FT foam/paper hing.
I am curious, what did you do here? do you have a link/reference?
Now you're talking. Tell me more so I can get a better idea about what my F-5 will do. You've got a single 1400 on that. I've got twin 1106s on mine with up to 3" props. What's your wingspan there? Mine is real small at 18". And you say it flew well. I'm hoping mine will fly ok on 2S but I can fit a 3S in it if needed.This is the Mk1 version I built.
Had it a few years now, its one of the first flite test planes I built. I have had a few happy flights out of it and was genuinely surprised on its maiden how well it flew (hence the Mk2) . I lost the signal once as it had a fake AR6210 Spektrum receiver in it (lucky I always set my fail safe on the ESC) it went beyond the range of that particular receiver. Luckily I got it back in one piece it glided into a field with long grass, just lost the canopy so built a new one. It gave my mate and my son some great amusement, watching me run after it.
Never liked the push rod system on this one though, so I've upgraded it on the Mk2. Plus its got real hinges, not the paper versions. The Mk2 has plastic control horns too as opposed to the standard FT plywood type.
The motor on this was a cheap generic 1400kv which came bundled with 7x5 prop and a 30amp ESC, it worked .
Sounds good to me, your MK1 is nearly 50% bigger than my F-5. I'll start with 2S and I have a feeling it might fly fine there for starters. Thanks.Usually fly the Mk1 off a 3S 1500 mAh plenty of performance with the old 1400kv. Don't know what the spec of the old motor is (didn't come with a spec) but with the new Sunnysky setup I should be getting 890g of thrust with the 8x6 prop with a 3s, wingspan rough guess-timation is 640 - 650mm.
Same motor with a 9x6 prop should give me around 1230g of thrust with the same 3s. However, the Sunnysky x2216-7 will run off a 4s too, so with the original 8x6 I can get 1380g of thrust (that's my next upgrade ).
wdym by a fake spektrum rx?This is the Mk1 version I built.
A Chinese counterfeit. Made to make you think it's the real thing. To make you pay the full price of the real thing. Ripping you off because that's how they do.wdym by a fake spektrum rx?
Yours is the mighty mini isn't it ? That's why it looks different, mine is the full size version.Tring out a kf-step wing on an FT MM F22. didn't put it on the lifting body part of it as it didn't make much sense (given were the CG marks are, clearly the body is figured in the lifting area).
We're gonna need a bigger boat.I have already started varnishing the bottom of the plane which is now finished. So is the power pod area, so once its dry I can mount the motor and finish off installing the electrics etc.
Once all the cables etc are secured I can test everything works, then fit the belly pan and paint it.
All I have left to do then is varnish the top of the plane and the belly pan (once the paints dried). All done, another plane to add to the collection, ready for a maiden.
Tomorrow night I am planning to build a new nose section for the Mk1 and remove the old damaged nose. If I get time this week and the weather is kind I will try to get them both out for some test flights. Looking unlikely as the weather forecast is dire, rain all week .
On a plus note I am going plane shopping and hopefully fetching home some bargains
in my case a bigger attic space.We're gonna need a bigger boat.
