dap35
I honestly wouldn’t go that big. That’s about the size difference between a standard sized plane and a monster plane.
I scaled a simple scout up to ~135% or 56" wingspan if I remember correctly and use a "C" pack. It flies nicely, but is not over powered by any stretch of the imagination. It will loop, but doesn't really have much vertical.
JasonK
Participation Award Recipient
Anyone have some spare time and an ez pack? I just designed this heinkel p.1079, surprisingly in under 2 hours. should be very simple, 6 sheets tiled. (letter) uploaded reference image and the non tiled and tiled plans. going to build maybe in the next week or so. posting the same thing on the heinkel build challenge thread. not yet a resource though. if somebody test it out and says that its nice, I will then put it up.
make a separate thread? I am printing it out and can see if I can get it flying.
F.K1999
I successfully repaired and modified my micro FPV plane.
But I got some problems with transportation due to undetachable wings. And wings themselves had very poor condition. So I decided to make a new detachable wing parts and smaller and lighter fins
It flew great. It was extremely stable and nice to fly. It became even more effective and fast if needed.
But then I got a problem with vtx. And trying to repair I made a stupid mistake that caused a fire that destroyed autopilot. So this bird will have unplanned vtx (and probably camera) upgrade and autopilot replacement.
Byrdman
Mini Simple Stick Question for the Guru's...
By my calculations, a Simple Stick at 71% would give you approximately 29.8" wingspan and 24.85% fuselage length, so I would probably just round up to 30" WS and 25% FL. I assume making the tailfeathers according to plans @ 71% would not be an issue either. Also, this would allow you to make a one piece symmetrical wing which IMO would be ideal.
What powerplant would you run with this Mini Simple Stick setup? A "B" power pack with a lower KV and larger (7"-9") prop or "A" with smaller prop (6") and higher KV? Or maybe a "C" size with 800KV swinging an even bigger prop (10"+) would work too for 3D, but you may have to enlarge the ailerons, rudder, and elevator a little. Any other suggestions?
rcbigtirepilot
I think the C and B motors would be too big, making the plane very nose heavy. With something like that an F pack on 3s might even give you vertical, plenty of power.
bwarz
That is funny! We have had that set for over 10 years. The DR-1 is a very stable flyer and I had read where the SE5 was a lot more difficult, but this one is definitely not. Built per plans with the servos glued just behind the CG.
did you do 3 channel or 4?
rcbigtirepilot
Just had my maiden flight on my DR-1 this morning!
Just had my maiden flight on my DR-1 this morning! You were right, it flew great! I was very impressed with the way my Mini Scout(RIP) flew, but this one flies even better. I guess the additional wing lift helps with the loss of altitude in the turns. Although not as fast as my MS, since I am using the same motor, but very nice flyer!!
you need some float planes man!
look at that glass down there, weird why would there be a boat sitting on a giant mirror, huh?
