K3V0
That’s a good tip! I was tracing around all the parts and cutting them out that way!
I finished the wing last night and that’s been satisfying!
I don’t know enough about the plane to have an opinion on the cardboard part you’re referring to but I’m interested in seeing it!
Sheriff
Nice work !
To help the pilot look downward, the Greenhouse cockpit is wider that the fuselage, as you can see.
I will keep you posted if/when I create the modd for the Storch.
Happy building!
Sheriff
..and to answer the original question; I WAS building this week-end !
This is my Mighty-mini Dragon Rapid. It is probably the 4th time building it, but this time, I am takings tons of pictures, hopefully to share my plans with detailled building instructions.
K3V0
Nice work !
Happy building!
Ok yeah, I see it. Thanks for dropping some knowledge on me! I think I’ll prolly save some scale details for the second fuselage. I know I’m gonna fly the first one into a wood chipper or something.
FoamyDM
Building Fool-Flying Noob
I took these plans by @Horseman3381 and printed them 8.5x11" letter sized paper. The goal was to get another plane for the PowerUp system, or some place to put in micro guys.
This uses paper plates for the foam. This makes it light and easy/cheap to purchase.
IMG_20191023_222741893.jpg IMG_20191023_222757263.jpg IMG_20191023_223125495.jpg
I used a bread tie to crease where the board was to be remove. A little glue and we are all good
IMG_20191023_223704613.jpg getting there now.
I little more work and it time to check the weight of it.
I would love for this to roll into the skylies, time for gear.
I made mine from three sized foam circles. A drinking straw box juice.
IMG_20191024_003951803.jpg IMG_20191024_004008132.jpg IMG_20191024_004034208.jpg
To balance, I needed 1 penny where each motor goes. And only a nickel in the cockpit.
Time to install the gear on the belly.
Looks great as finished and ready to fly.
buzzbomb
I know nothing!
View attachment 146257 View attachment 146258 View attachment 146259
View attachment 146260 View attachment 146261
View attachment 146262 getting there now.
View attachment 146264 View attachment 146265 View attachment 146266
View attachment 146268 View attachment 146269
Oh, heck yeah! You came through all the way! Darn, but if that isn't a beautiful little P38! You, sir, totally rocked it! Congratulations and well done!
K3V0
Nice work! So much hard work! And I love the details like the bread ties and pennies to give it a good sense of the micro you’ve constructed!
Sheriff
Just some slow progress on the mini scout, refuse to paint until I can keep one in the air more than 30 seconds...
Climb a few feet above the ground (like on a picnic table) and throw your completed model a few times without power, just to see how it glides and ajust the trims as much as possible BEFORE commiting to your maiden flight.
If trimmed correctly (and with the C.G. in the right place) it should glide with no control inputs. If not, ajust some more.
The first flight is often so much harder than the 3th or 4th would be, simply because the trims are usually totally off.
That's why the best way (when possible) is having an experienced pilot for the maiden, who than passes you the remote.
Good luck! Keep us posted.
