Elijah R
Hello,
Does anyone know of a good brushless inrunner capable of a continuous power rating of about 12-15 kW that has reasonable weight (under 5kg)?
For a bit of context, I am building a drone and I need two motors like this to connect to the back of two gas turbines in the drone to output a large amount of power for the drone. Also, I will be liquid cooling these motors so heat will not be an issue.
(kV and output voltage of motor doesn't matter too much, but the output shaft will be spinning at about 6200-6300 RPM)
I have looked around for quite some time now and can't seem to find exactly what I need. If all that exists are outrunners or heavy inrunners, that is fine but light inrunners are preferred for mounting and cooling reasons.
I thank anyone in advance for any help!
