AircPirateNinsei
Foam Board and Filament Shugenja
Here I present you the little brother of Argus, the Mini Argus (prototype) with only 650 mm (25.59 in) wingspan.
You will only need one sheet Flite Test Water-Resistant Foam Board By Adams (20 x 30 in) and a Flite Test Power Pack A (or compatible electronics) for the build. Since I only have one FT WR Foam Board sheet left, which I still need to finish the Thunderbolt, I had to use Airplac Premier Foamboard, which unfortunately has considerably more weight. The AUW of my Mini Argus with a 2s 950mAh Turnigy nano-tech battery is 265 g (9.35 oz). If you build the Mini Argus with Flite Test Water-Resistant Foam Board By Adams, you will save about 44 g (1.55 oz) and get far below the magic 250 g (8.82 oz) limit. The Mini Argus has a KFm4-airfoil, which is a good choice for aerobatic planes. I'm looking forward to the maiden flight!
