AircPirateNinsei
airc-pirates.com
Here is the larger version of the Rascal Racer with a wingspan of 1000 mm or 39.37 in.
Scaling up the parts was easy but adjusting them back to the thickness of DTFB took some time.
The result is a BETA plan. I still have to test the thrust angle, that is the reason for the BETA-plan.
The prototype is ready for the maiden flight.
This version has a rudder.
Specs
Wingspan: 1.000 mm | 39.37 in
Center of Gravity (CG): 37 mm | 1.46 in
Length: 690 mm | 27.17 in
Weight (without Battery): 452 g | 15.95 oz
Weight (with Battery): 690 g | 24.34 oz (4S 2200 mAh)
Expo: 30 %
Channels: 4 (Throttle | Ailerons | Elevator | Rudder)
The weight of the brushless motor is only 70 g, so the rudder and elevator servos must be placed near to the front.
Electronics – Test Setup
Motor: 2836-1100kv
Propeller: 7×4.5
ESC: 40 A 4S
Servos: 4 x 9 g (HXT900 or TGY-1800A)
Battery: 2200 mAh 4S
Build Plan – BETA Version
DOWNLOAD FREE BUILD PLAN
If you want a smaller version, look here: AP Rascal Racer (700 mm | 27.56 in)
Specs
Expo: 30 %
Motor: 2836-1100kv
Propeller: 7×4.5
ESC: 40 A 4S
