AP Super Tucano (FT Power Pack F | swappable)
AircPirateNinsei
airc-pirates.com
STATUS: The maiden flight was successfully completed and the BETA-plan is published!
GENERAL SPECIFICATIONS
WINGSPAN: 800 mm | 31.50 in
CG: 45 mm | 1.77 in
LENGTH: 680 mm | 26.77 in
DRY WEIGHT: 304 g | 10.72 oz (TYPE S)
ALL UP WEIGHT: 390 g | 13.76 oz (TYPE S)
EXPO: 30 %
CHANNELS: 4 (THR | AIL | ELV | RUD)
RECOMMENDED SETUP - TYPE S (works wit FT Power Pack F):
MOTOR: 2300 kv (2205)
PROPELLER: 6x4
ESC: 20 A
SERVOS: 4 x 5 g
BATTERY: 1000 mAh 3s
RECOMMENDED SETUP - TYPE R:
PROPELLER: 6x4
ESC: 30 A
SERVOS: 4 x 9 g
BATTERY: 1300 mAh 4s
DOWNLOAD:
DOWNLOAD FREE BUILD PLAN
VIDEO:
PICTURES:
_______________
Old first post:
Inspired by nerdnics 800 series, I decided to build an Embraer EMB 314 Super Tucano - also known as ALX or A-29.
I designed this plane without PosterBoard, so it is an "easy to build" airplane. You need 2 sheets of FoamBoard.
You can also use your FT Mini Power Pod for this plane.
The BETA plan is almost ready!
jaredstrees
Great looking plane! I've always liked those super tucanos. I'm about to decommission a SE5 that is almost beyond repair. This may take it's electronics!
AircPirateNinsei
airc-pirates.com
The maiden flight is expected to take place on Saturday. I am still thinking of placing the servo for the rudder under the vertical stabilizer, then the battery can be placed more forward - let's see. If the first flight goes well, I will publish the BETA plan next week. So stay tuned! :)
AircPirateNinsei
airc-pirates.com
The Tucano flew like a leaf in the wind. It needs more weight. So I will mount the servos for the rudder and the elevator in the tail and put a bigger battery in the nose. Maybe one with 1300mAh or one with 1600mAh 3s or 4s. I ordered these four types of batteries and I am happy if I can install them. So it'll take one more flight before I publish the plans. But if you don't want to wait, you can send me a PM to get the link to the current BETA plan.
AircPirateNinsei
airc-pirates.com
Yeah, it ruled the sky at the local flying club. Here's a snapshot:
During the last test flight the Tucano had the following setup:
  • Emax RS2205-2300KV Racing Edition Brushless Motor
  • HobbyKing 30A BlueSeries Brushless Speed Controller
  • Turnigy Nano-Tech-1300mAh 4S 45 ~ 90C Lipo-Pack
I exchanged the 5g servos in the rear against 9g servos, to have more space in the nose to position the battery for the perfect CG. With the 5g servos the battery was directly at the front edge of the wing and the CG was a bit too far forward. Now it fits.
These changes have no effect on the parts in the current plan (V0.1), but on the first page with the information. I'll have to change them. A photo must also be taken for this page. And I want to build a second one to verify everything to publish the plan as V1.0. If you don't want to wait, send me a PM and I'll send you the link to the current beta plan (V0.1).
AircPirateNinsei
airc-pirates.com
Not so far, but why not? With this model you can use 5g or 9g servos. If you want to use an EMax GT2215/09 (C Pack) or an EMAX 2213-935 (B Pack) brushless motor instead of an EMax 2205 (F Pack), I just need to create other Power Pod Spacers and a different Power Pod Plate because the C and B Pack motors are longer than the F Pack motor. They all fit on the FT Mini Firewall and the FT Mini Power Pod and they all fit in the nose of this model.
Yes to C Pack, but I was also thinking about something in the 1000mm - 1200mm size. Even up to 1500mm I suppose. I fly in wind almost every time and the smaller (lighter) planes are more challenging.
I am back from a 30yr hiatus and having a good time. Experimenting. I do realize that just resizing isn't enough... there would be other considerations with a bigger plane.
AircPirateNinsei
airc-pirates.com
Welcome back! I'm sorry, but I can't create a bigger Tucano this year. As a C Pack model with 1000mm wingspan I currently only have the Godai or the Rascal Racer available. Here are the links to the threads:
