APM 2.6 with GPS and Compass
Tymtravler
I would like to know has anyone used the APM 2.6 in a V Tail copter successfully. I just called 3D Robotics to inquire on some of the features and tech support said that they do not support the V Tail configuration. They said I may try to set it up as a quad but they don't think it would work. If anyone has I would be greatful for a copy of your settings to get started.
Thanks
Mustang7302
If you can customize the throttle/pitch/roll/yaw for each channel like on a KK2, take the yaw out of the front motors and add in 50% power to the yaw input on the rear motors. Will take tinkering to get the values scaled desirable, but in short that is how the KK2 sorts it out.
aidan284NZ
Hmmm I sure after you select the quad firmware it allows you to choose either plus, X or V Tail. I could be wrong though
