Are the Pre-Loaded models in the Radiomaster Pocket available for download?
p40whk
I was watching the Flightest "Worlds best Trainer" video and at the 3:30 minute mark you reference the Radiomaster Pocket now has pre-programmed models installed. I have a radiomaster pocket that I purchased previously and was wondering if there was a location I could download those models and install them to my transmitter? Would save a ton of time especially if you have multiple models.
Couldn't find any on the website but it would be great to be able to load these in edgeTX
Insanely Addicted Techno Geek
Ooph..... I usually delete those and start from scratch. I'll do some digging, but I think they will be found on the RadioMaster Web Site.
Yeah the factory SD card contents can be downloaded here :
There are links for both the CC2500 and ELRS pocket radios. The models will be on those images.
Cheers!
p40whk
Cheers!
Perfect! Thanks so much!
Just a word of caution.
Be careful using someone else setup. Unless you install your servos the same way they did theirs, your servos may be reversed.
That is why I just delete them and start from scratch. I then use my mappings as a source for any new models I create as a copy. The ones that come with the radio are only a starting point as examples of different types of vehicles.
@LitterBug , isn't he looking for the preloaded FT models for the Pocket?
Hmmm... not sure.....
After closer examination.... yes. OOPs
That must be something they add to the SD card on the FT branded units they sell.
dmco
I had this same question, and asked FT support: they do not currently offer the pre-loaded models for purchase separately. Curiosity got the best of me, so I ordered a FT Pocket ELRS to see what models it comes with. They have the following models setup:
  1. FT PLANE
  2. FT TRAINER (same as above just with trainer slave enabled)
  3. FT AURA5
  4. FT WING
  5. FT TWIN
  6. FPV DRONE
  7. PLANE
  8. DELTA
As a newcomer, I was mostly interested in the FT PLANE model, which turns out to be a basic setup with triple rates (65%/80%/100%), expo 30, and a throttle cut. Nothing you couldn't do from scratch, but it was helpful for me to see an example EdgeTX model configuration. Some of the other models have slightly fancier setups for flaps or twin engines, etc.
Was it worth the extra $38? For me yes, it helped to learn and compare EdgeTX settings. Plus I am happy to support Flite Test. Plus the red plastic color and logo help strike up conversations at my local club.
alfredborges
As an alternative to posting the SD card contents, it would be great if someone would load the pocket into edgetx companion and export the models . Alternatively, the model setup could be loaded then printed out
You do have to be careful importing models, but it also helpful to be able to view and compare set ups
FT created the profiles and they are part of the image for the FT branded Radios. If they don't want to give them out, that is their call. Copying them off and sharing them is not recommended.
It is on a sd card..... how hard can it be to write your own data to make it work? Annoying involved, perhaps but not hard.
John M
Is the Aura5 model preloaded on my FT Pocket configured for flapperons? The Aura5 unit has 2 channels setup for ailerons. I am thinking 1 notch of flaps would make takeoffs and landings a little more manageable.
No. That would be a function of the Aura, not the Radio. When using a flight controller like the aura, ALL mixes involving the main control surfaces must be handled by the Flight controller.
