Arkbird to ImmersionRC VTX
Can anyone tell me what connections are needed to connect the GoPro 3 to Arkbird then Arkbird to ImmersionRC TX? I have bought the generic HK gopro 3 cable, hopefully that will work, but what are people using from Arkbird to ImmersionRC TX?? Photos would be great if you have them.
RoyBro
It would be helpful if you could supply a link to the Arkbird manual. It should be a simple hook up, but you may have to fabricate a cable.
What voltage is required by the Arkbird? If it takes 5v, that would make the hook up even easier. The Fatshark transmitter can supply the 5v, and you would only need one cable between the Fatshark and the OSD.
