I just got my first plane the Bixler RTF, after putting it together and charging the stock batery using the stock charger, I conect it and the ESC doesn´t beep, a red led blinks in the rx and I try to do the rx tx binding and it doesn´t work, I´d really appreciate your help since I have no idea what to do.
Hello panyflx, and welcome.
It would be appreciated if you could keep the question on one thread.
Just a kind suggestion
But anyway, do you have a voltmeter? So you could measure the battery voltage.
Let's go through the setup as well.
-The black and white and red cable coming from the ESC should go to the throttle channel on the receiver.
-The two wires (red and black, separate) coming out from the ESC should go to the battery with the right polarity.
-The three wires coming out from the other side of the ESC, (same color) go to the three wires on the motor.
-The servo cables go in the corresponding channel in the receiver.
Now the troubleshooting:
-The receiver gets current, which means that the BEC of the ESC is OK.
-Are the other servos moving? reverse the plug and try again.
-The ESC does not beep when plugged in - check motor connectors.
Note that the ESC doesn't beep, the motor does.
Good luck with your motor.
