Latest Release
Aura Firmware v1.25
- Update for Aura 5, Aura 8, Aura 8 Pro, and Aura 12 Pro product releases
- Aura 8 Specific Changes:
- Add support for the RV-8 10E G2
- Add 6Axis Support for all Aura 8 products
- Add retrofit logic so any older product will be able to use 6Axis Level Assist or Launch/Takeoff Assist without needing additional programming
- Add Quick Flip procedure logic to toggle Flight Mode 1 to a 6Axis Level Assist Control mode without needing a PC or Transmitter.
- Simplify Open Stock Quick Set Logic by removing the ability to create a Sport or 3D configuration with the Gear Switch
- Available July 2025
- Aura Pro Specific Changes:
- Update Quick Trim procedure so Quick Trim can be started at any time by pressing Button2 rather that having to cycle the power
- Add Quick Change Mode to match Aura 5 functionality by pressing Button1 and Button2 together so you can:
- Check or change gyro sensor directions with the transmitter
- Toggle Flight Mode 1 to 6Axis Level Assist Control Mode
- Toggle between Ailerons and Elevons on the Servo Ports
- Turn on/off Proportional Ch8 Master Gain
- Aura 5 Specific Changes:
- Update Level Assist retrofit logic for simplicity and consistency with Aura 8/Aura Pro
- Add Quick Flip procedure logic to toggle Flight Mode 2 to a 6Axis Level Assist Control mode without needing a PC or Transmitter.
- Common Changes:
- Blue LED will slow flash if the Aura goes to Failsafe but then recovers the signal
- Add Roll to Pitch Angle Cmd Logic for Level Assist tuning
- Update LiveData logic for generic read/write for future development
- Update USB Driver to be a generic CDC ACM instead of the custom ST-Micro CDC Driver. This is for future development.
- New features are detailed on the new Quick Start Overview Documents for Firmware v1.25+
- FT Aura 5 Quick Start Overview (PDF) - English - Updated for Firmware v1.25+
- Aura 8 Quick Start Overview (PDF) - English - Updated for Firmware v1.25+
- Aura Professional Quick Start Overview (PDF) - English - Updated for Firmware v1.25+
Previous Releases
Aura Firmware v1.24
- Small update for Aura 8 product release
- Add support for the Extra 300 60E
- Shipped on Extra 300 60E but never allowed for Firmware Update to other products
Aura Firmware v1.23
- Small update for Aura 5, Aura 8, Aura 8 Pro, and Aura 12 Pro product releases
- Add support for the Laser 200 60E
- Available May 2025
- Common Changes:
- Fix SRXL2 logic so servos will not activate until SRXL2 receives valid data rather than just an SRXL2 Handshake
- Make Autodetect start logic a more consistent 20 second delay
Aura Firmware v1.22
- Add support for the Ventique 60E G2 Pro
- Available Jan 2024
- Add support for the Flex FP Aura Products including the FP Edge 540 and FP Ultimate
- Available April 2024
- Common Changes:
- Improve Flash Memory powerup timing robustness
Aura Firmware v1.21
- Available for Aura 5, Aura 8, Aura 8 Pro, and Aura 12 Pro on August 4, 2023
- Common Changes:
- Improve SBUS channel order detection in Auto-Detect
- Improved FrSky Auto-Detect setup logic
- Improve center offset logic for FrSky SBUS systems
- Learn Throttle Polarity for PNPs with SBUS since Futaba default now varies between Transmitters
- Add support for the Twin Otter 80E
Aura Firmware v1.20
- Available for Aura 5, Aura 8, Aura 8 Pro, and Aura 12 Pro in July 2023
- Shipped on the RV-8 60E G2
- Common Changes:
- Add Aileron Differential
- Add support for the RV-8 60E G2
- Bring Aura 5 up to date with Aura 8 features/fixes such as:
- Added Aura Flap System capability
- Improved SRXL2 Handshake Robustness
- Added support for a Third control mode running in a flight mode
Aura Firmware v1.19
- Available for Aura 8, Aura 8 Pro, and Aura 12 Pro in April 2022
- Not yet available for Aura 5
- Common Changes:
- Improve Spektrum Satellite Diversity Failsafe Learning logic
- Logic/timing is more robust for learning Spektrum Satellite Diversity Failsafes.
- Add support for QQ Yak-55 10E
Aura Firmware v1.18
- Available for Aura 8, Aura 8 Pro, and Aura 12 Pro on December 9, 2021
- Common Changes:
- Add logic to learn Throttle Polarity when Auto-detecting on Open Stock products. This should reduce crow mix direction inconsistencies after Auto-Detect for Aura Open Stock products.
- Add support for CAP-232EX+ Stock/Expert (2022) profiles
- Fix Aura Pro SRXL2 Handshaking implementation on Aura Pro Port A
Aura Firmware v1.17
- Available for Aura 8, Aura 8 Pro, and Aura 12 Pro on October 5, 2021
- Common Changes:
- Update JETI EX-BUS processing logic to support latest JETI Firmware changes that could cause servo glitching with certain JETI modules and JETI firmware combinations
- Add logic for soon to be announced feature
- Add support for RV8-10
Aura Firmware v1.16
- Available for Aura 8, Aura 8 Pro, and Aura 12 Pro on May 20, 2021
- Available for Aura 5 on June 25, 2021
- Common Changes:
- Update SRXL2 Logic for additional robustness for any SRXL2 Timeout or SRXL2 Receiver Brownout possibilities
Aura Firmware v1.15
- Shipped on Open Stock Aura 8, Aura 8 Pro, and Aura 12 Pro in late December 2020.
- Common Changes:
- Minor changes for future products and features
Aura Firmware v1.14
- Available since mid-August 2020 via Aura Config Tool update followed by Firmware Update procedure
- Available for FT Aura 5, Aura 8, Aura 8 Pro, and Aura 12 Pro
- Common Changes:
- Add support for SRXL2 Receivers SPM4650 and SPM4651T
- Add Aura Telemetry Tune feature to allow SRXL2 Receivers to adjust Aura settings directly from the transmitter
- Add support for JR Mode A
- Add support for F-100D Super Sabre SPNP
Aura Firmware v1.13
- Available in February 2020 via Aura Config Tool Firmware Update procedure
- Add support for FT Aura 5 hardware
- Common Changes:
- Correctly Auto-Detect and differentiate between Futaba's SBUS channel order and FrSky's Default SBUS channel order
- Add Support for "Stick Relative" Stick Priority that is independent of each Flight Mode's Dual Rate/Expo Settings
- Add Input Re-Map functionality
- FT Aura 5 Specific Changes:
- Add Auto-Launch features
- Add Bank Assist and Level Assist features
- Aura Pro Series Changes:
- Prevent bug that occurred if S11 or S12 was set to 'PWM Capture'
Aura Firmware v1.12
- Available on October 18, 2019 via Aura Config Tool Firmware Update procedure
- Software Changes:
- Small update for consistency in future features and releases
- Initialization timing tweak for Aura Pro startup timing
Aura Firmware v1.11
- Shipped on production Aura 8 Professional and Aura 12 Professional in August 2019
- Software Changes:
- Add support for Aura 8 Professional and Aura 12 Professional
- Dual EC-3 Battery Sharing
- Battery Voltage Monitoring LEDs
- Add Dual SBUS Diversity Receiver capability
- Add SBUS Digital Output to support SBUS Servos or Additional Channels
- Quick Trim activation thru Push-Buttons rather than Bind Plugs
- Add JETI EXBus capability
- Improved LED Notifications
Aura Firmware v1.10
- Shipped on production Mamba 60E in July 2019
- Software Changes:
- Add support for Mamba 60E
Aura Firmware v1.09
- Shipped on production FlexJet TV Auras in March 2019
- Software Changes:
- Add support for FlexJet TV
Aura Firmware v1.08
- Shipped on production Open Stock and RV-8 Auras in late December 2018
- Software Changes:
- Add support for RV-8
- Add Bounceback Gain feature in Open Stock Auras.
Aura Firmware v1.07
- Used for production of QQ Extra 300 G2 Aura in late November 2018
- First firmware to support new Aura Bootloader v2.0which does not require a Bind Plug for firmware updates
- After updating to firmware v1.07 with an older bootloader, Aura Config Tool will update the Bootloader.
- Software Changes:
- Add support for QQ Extra 300 G2
- Add support for future products and features
Aura Firmware v1.06
- Shipped on production FlexJet Aura.
- Released on 3/15/18
- Fixes potential issue where Dual Spektrum Remote Receivers may not be correctly auto-detected
- Mandatory update for Dual Spektrum Remote users. Recommended for all users.
- Software Changes:
- Added Firmware support for FlexJet
- In order to always correctly detect Spektrum Remote A+B Diversity, additional logic was added to the Spektrum Remote processing code. If you see a flashing Red LED after updating to Firmware v1.06, this is an indication that you need to Re-Bind your Spektrum Remote Receivers.
- Remote Receiver users must Re-Bind after firmware update.
- Please review the 1.04 and 1.05 notes as well.
Aura Firmware v1.05
- Shipped on production QQ CAP-232EX Aura on February 15, 2018
- Software Changes:
Aura Firmware v1.04
- Available via 'Firmware Update' in Aura Config Tool on February 22, 2017
- Shipped on production Mamba 10 Aura in Spring 2017
- Running change for Open Stock Aura after Spring 2017
- Software Changes:
- Added support SRXL with for latest generation of Spektrum Receivers(AR8010T, AR9030T, AR9320T, AR9140T, AR12310T, AR20310T).
- Spektrum changed their SRXL format between the latest generation of receivers and previous SRXL receivers such as AR9020 and AR7700. Firmware v1.04 was released to support the newest SRXL format.
- At the time of writing, the new generation of Spektrum Receivers did not correctly pass failsafe values thru the SRXL port. Make sure to plug the Throttle into the Spektrum Receiver throttle port if using a new receiver with SRXL. Thoroughly test the failsafe behavior before flying!
- Firmware v1.01 - v1.03 allowed a Single Spektrum Remote Receiver to be bound in either 'Mini Port A' or 'Mini Port B'. In firmware v1.04+, a Single Spektrum Remote Receiver will only bind in Mini Port A.
- While two Spektrum Remote Receivers can still used together for Diversity, please rebind them to your transmitter after updating to firmware version 1.04+.
- Update Quick Set Procedure to require the pilot to set the Control Surface directions before pulling the bind plug.
- In firmware v1.01 - v1.03, the pilot set the Model Type, Sensor Orientation, and Master Gain functionality before pulling the bind plug. After pulling the bind plug, the pilot would then set the Control Surface directions and check the Sensor Direction by moving the aircraft.
- In firmware v1.04, the pilot sets the Model Type, Sensor Orientation, Master Gain functionality, and Control Surface directions before pulling the bind plug. After pulling the bind plug, the servos are now disabled except for testing the Sensor Direction by moving the aircraft.
- Add feature to turn Aura Mixes On/Off via a Transmitter 2 or 3 Position Channel Switch.
- Add feature to create a Gyro Kill Switch via a Transmitter Channel.
Aura Firmware v1.03
- Available via 'Firmware Update' in Aura Config Tool in late August 2016
- Shipped on production Open Stock Aura 8 in early September 2016
- Running change for QQ Extra 300 production some time after early September 2016
- Software Changes:
- Firmware v1.02 did not correctly calculate Exponential values. The Exponential calculation has been corrected in Firmware v1.03. Please be aware the control surfaces may feel different after updating from v1.02 to v1.03 and should be tested before flight.
- Add support for Cessna 170 PNP
- Add support for Spektrum AR7700 SRXL protocol and CRC
Aura Firmware v1.02
- Available via 'Firmware Update' in Aura Config Tool in mid November 2015
- Initially shipped on release of Open Stock Aura 8 in November 2015
- Running change for QQ Extra 300 production in January 2016
- Firmware v1.02 incorrectly calculated Aura Exponential values which removes any exponential feeling on the control surfaces. This issue was fixed in v1.03.
- Software Updates
- Add support for Open Stock Aura
- Add Quick Set and Quick Trim features
- Add USB power-up robustness logic
- Add capability for dual Control Modes per Flight Mode
- Add support for SubTrim in uSec steps
- Introduce Config File Version v1.01
Aura Firmware v1.01
- Stock of QQ Extra 300 Aura 8 updated to v1.01 in mid August 2015
- Available via 'Firmware Update' in Aura Config Tool in mid August 2015
- Software Updates
- Add Satellite Remote Receiver robustness logic
- Add support for DSM2 modules in JR Transmitters
- Add robustness for initializing Aura under High Rate conditions
- Add support for Futaba SBUS2 FASSTest
Aura Firmware v1.00
- Initially released on QQ Extra 300 Aura 8 in early August 2015
- No longer authorized by Flex Innovations for use. Flex Innovations can only support v1.01+.
