Aura 5 lite
rickg
I am having issues getting the Aura 5 lite to function correctly. I followed the basic setup instruction everything worked great as long as I am in the quick-change mode. Everything is correct as they state but when I exit out all I can get from it is some slight twitching on correction. Does anybody have any information that might help. I am using a radio master tx16s and Radio master ER6 receiver.
Insanely Addicted Techno Geek
Depending on what flight mode is selected, slight twitching may be all you will see. If you are in manual mode, the control surfaces should do what the stick motions dictate. In the stabilized modes, the FC will do what it thinks is needed to get the plane to react the way it wants it to. This is usually much less than most people would expect.
Do you have a flight mode switch set up, and do the different modes behave differently?
rickg
launch assist is not working The lights on the board are solid yellow and solid green. All normal controls are working correctly.
randyrls
Randy
Had the same problem. You need to set the trims via the Aura settings. If the Trims are too far off, the Launch Assist will not engage. Zero the trims and see if LA will engage. (Don't fly with the trims centered) but go through the trimming process.
