kentross81
I have a standard 2 elevon flying wing and my Taranis X9D with old OpenTx, everything works fine.
Add the Aura Lite, configured for S.BUS, and setup a new model with no radio mixing, and 1 channel for Aura stabilization control- Just like in the videos.
I have 3 issues which may be related?
1) Fast ESC beep on power up, like ESC needs calibration. If I enter Basic Setup Mode on the Aura (both buttons pressed until green flashes) the ESC beeping stops, and upon exiting Basic Setup Mode all is fine. with the throttle.
2) I cannot get the Launch Assist to arm. The switch for setting the stabilization mode of the Aura works (off, horizon, acro) but this fails in all 3 settings. No red blinky!
3) My Aileron, or Elevator correction from the Aura is always backwards. It is correct for manual control, but in Basic Setup Mode or in horizon/acro switch setting) 1 or the other is always wrong. Trying to correct this via the sticks in Basic Setup Mode does not work.
Mine came with v1.21 firmware. I did upgrade it to v1.22. Was this an "oops"?!
Thanks for any feedback, see you at Flite Fest!
