airbikebill
Hi. New to the forum. I'm installing a Aura lite in a Twisted Synergy. I used the configure tool for set. All servos and control surfaces going in the correct direction. Aileron and yaw sensor direction is correct but the pitch sensor direction is backwards. I have worked on this for hours. I even turn over the servo horn and reversed the servos but ended up with the same thing. You point the nose up and the elevator goes up instead of down. Any help would be appreciated. Thanks
