Is this diamond just a replacement for the last one?Good luck
Thanks Guys!
So the maiden did not go well. The plane developed a glitch so that at full power or changing power to the EDF, the elevator servo went crazy, deflecting partially or fully up. So full power at launch, plane tried to fly straight up. Take the power off, slight up jerk then settled into flight, power up again, plane pointed straight into the air. It felt like a plane that was going from properly balanced to massively tail heavy every couple of seconds. Managed to glide her in for landing with no damage and that is when I discovered the weird elevator behavior. Switch the elevator to one of the aileron channels and it did the same thing. I thought (and still think) that its interference on the signal line caused by the EDF motor wires. Did a little hacking and routed the servo wire outside the plane to the hatch. On the ground this seemed to solve the issue. However, in the air for the second flight, the problem returned with a vengeance. Managed to get her down again with little or no damage and decided not to throw her up again until I had some time to sort out this servo problem.
Oh well, win some lose some.
@Therry - I hope your maiden went better?
DamoRC
Maiden went ok, first attempt she was a lawn dart. Nose in the soft dirt, throw was to steep. Had to pull her out, nose damage but not to bad. Had to give full up. Second attempt little better, bounced of the grass to hold. Third time success, smooth throw, with full up and away she went.
Once airborne it is a stable flyer. Make some repairs an try to find more up throw in elevator. Speed was good 4s 3700.
Therry
DamoRC,
You do you plan to release a set of full-size plans for this model?
Have been a while but today she got some color. The horizontal stab was indeed not horizontal. Thanks for the tip. Now she flies nice. Had to make a new nose, a crash broke the nose.Great! Congrats on the maiden! I am glad you got her into the air eventually. I am wondering about the need to give her "full up". Do you mean that to launch her you have to apply full up elevator to get her to start flying, or do you mean that in the air you needed to trim the elevator all the way up to keep her flying level?
A couple of suggestions - first, check if there is any incidence in the horizontal stablizer that might be creating a push down on the tail. Second, you could try moving the balance back a little.
Anyway, sounds like she is flying, just needs some tweaks and nose repairs
Looking forward to seeing her painted up!
DamoRC
You are getting very handy in building does diamonds. Nice work!And then there were four....
Just delivered another Diamond build to a friend at the field. Really happy with how these colors work on this plane.
DamoRC
Nice ! Like what you did with the cheater inlets.Have been a while but today she got some color. The horizontal stab was indeed not horizontal. Thanks for the tip. Now she flies nice. Had to make a new nose, a crash broke the nose.
Thank you DamoRC. The inlets as on the plan are to small. This mod works and doesn't look to bad.Nice ! Like what you did with the cheater inlets.
DamoRC
Proof of flight. See
hi, very interesting build a detailed build precess a clear plan.
i will build one soon because is so fun to fly an rare plane in my club
thank you
I just had a 90mm EDF, ESC and 6 Cell Battery land on my door....
Then i Remembered seeing your 90mm version of this in Person!
