AXN Floater/ Clouds Fly FPV Pod
Hey Gang
I have been working on a simple FPV Pod for my AXN Floater/ Clouds Fly (see below).
It allows you to easily carry a 5.8GHz TX, Remzibi and 1/3" Sony CCD Video Camera. I have attached plans if anyone is interested. It is made using .060" Thick (1.5mm) Sheet Styrene. Simply print out the plans, cut the shape, drill the holes and bend.
Hope this helps
Cheers
DM
Hey Gang
Just thought I'd add a few more tips.
1. The front of the pod where the camera mounts is angled slightly down for better vision.
2. I attach the GPS, Pod and Remzibi using adhesive velcro.
3. The Video TX is zip tied against the back of the Pod.
4. The camera is held in position using a rubber O ring.
5. I used a 16mm spade bit in a drill press to create the hole for the camera.
Hope this clarifies a few points.
Cheers
DM
