Harley, I'll answer both this question, and the one you posted on the Kinetic 800 as well. This would be the better of the two to learn on for a few reasons.
First, the Kinetic will be a faster plane. The faster the plane, the harder to learn on because you don't have as much time to think about the corrections you'll need to make in flight.
Second, the Bixler, AXN, Wildhawk type planes have the propeller in the back. WHEN you nose it in, it doesn't break the prop. So as long as you didn't break foam, you can toss it right back in the air.
Third, the Bixler has a 1400 mm wingspan to the Kinetic's 800 mm. With a larger plane, you can see it easier, which is helpful if you accidentally fly it further from you than you intended.
Fourth, and last for now, the Bixler/AXN is much more upgradable than the Kinetic. With mods like FPV and Aerial Photography, it is something you can grow with.
