Give it a shot yourselves, guys! Foam board is cheap and easy to work with. You don't have to be a Sketch-up expert. Draw the shapes directly on the foam board, cut, tweak, redo.... Even if it doesn't come out the way you hope, you will have learned a lot and be much closer to the point where you can build one as you want.
