B-24 DTFB **update: It flies. now w/plans
A couple months ago my friend had linked me to nerdnic's videos about designing foam board planes like Flitetest does them. I finally got around to watching them all (3 hours!) and started looking around for something to try out. I quickly found this great balsa plans site: http://www.outerzone.co.uk
After combing thru plans for an hour or so i had a few that i liked and the one i decided to try was a set of b-24 plans found here:http://www.outerzone.co.uk/plan_details.asp?ID=6706
Using inkscape i dropped in the power pod pdf and sized the plans to match the same scale. That is, that the fuselage will have a similar size as viewed from the front as swappable would. I believe this will give me a close scale look for some small motors to be installed on the wings.
Inkscape makes it very easy to adjust your shapes to match any contour so it went fairly quickly. The hard part is figuring out how the foam with meet up and glue together. As i found in my first build there are definitely "better" ways to make parts connect.
Just thought i would share my current status and pics. I will update as i get things done.
With current build i was not too concerned with making the shape perfect. For instance i didn't want to worry about how the wing would slide thru the body so i just left a rectangle cutout for easy wing testing. The tail i printed out per the balsa plans, but in reality i think trying to get a split elevator will add to much difficulty to the build. I did end up cutting and installing the former's for the top and nose so that i could see if the curvature looked ok and if they even were printing out correctly. And as i am reminded every time i build a flitetest plane, i really don't know what i am doing with construction paper. None of this mattered after i had my successful free flight tosses though!
Current weight of the frame is about 230g
Wingspan: 47"
Fuselage length: 26"
Now that i have finished the glide tests i need to get some electronics. I am currently planning on a 2s setup.
4x 1806 motors 2280kv
5030 3 blade props
12a esc's
1000-2000mah 2s
3x 8g servos. No rudder as it will have differential thrust.
I expect the flying weight be in the 500-600g range and if i keep the throttle down i expect 5 minutes on a 1000mah battery.
And i need to figure out the landing gear.
And adjust the body so the wing goes thru it, like the FTspitfire.
In this video the wind was coming from the left and each throw i was adjusting the weight back slightly.
update 8/20/2015
Wingspan: 47"
5030 3 blade props
12a esc's
1000-2000mah 2s
update 8/20/2015
