Thanks,You do great work! I like how you mounted it and did you 3D print the mounts for the landing gear or did you get them somewhere else. I made mine out of wood and when I was thinking about it at the beginning it seemed like I could fit it just below the spar and not affect its integrity. After it is a bit more tight then I had thought and I like your placement a bit better. Let me know how stable it ends up being (over time) with the spar cut like that.
You gear is mounted closer together so I would also be interested in hearing how stable it is in ground handling.
Finally I haven't yet got to the rear wheel, but i do have a solution in mind. If you could share pictures of how you setup yours I would love to see before I start on my own idea. Any tips on building it would be great so I don't have to rip out mine as well when it doesn't work the first time.
Please keep sharing pics and I would love to see the maiden and how it handles with the additional weight of our retracts. Good Luck!
Generally when making a roll to the right I use just right aileron on 75-100% throttle and level out using up elevator. I realized that on lower speed around 50% throttle I some times have to push the elevator down when inverted on the part of the roll and then up elevator to exit the roll leveled. I think that using the rudder I can just get the roll done on lower speeds, yet to be tested.@mayan - so with your roll (say to the right) you add up or down elevator?
Looks amazing can’t wait for the maiden video .View attachment 141067 View attachment 141068 View attachment 141070 View attachment 141071 View attachment 141072 Almost there!
Noticed that I need to adjust the thrust angle though, so that's going to delay my maiden 🤨
NiceView attachment 141067 View attachment 141068 View attachment 141070 View attachment 141071 View attachment 141072 Almost there!
Very Nice!View attachment 141067 View attachment 141068 View attachment 141070 View attachment 141071 View attachment 141072 Almost there!
I did the rudder thing in my Scout maiden... HOLY CRAP was it fast and surprisingly lost next to no attitude. It was awesome. I was practicing some inverted and was doin these turns where you climb to vertical, half roll then level out to change direction, I'm sure there is a name for it. Looks cool though. and hammer turns I want to dial in as wellUsing the rudder along with the ailerons will just about double your roll rate.
With the rudder and aileron input 100% to the right or the left depending on what direction you want to roll at 50% throttle was a quick roll with little to no loss of altitudeGenerally when making a roll to the right I use just right aileron on 75-100% throttle and level out using up elevator. I realized that on lower speed around 50% throttle I some times have to push the elevator down when inverted on the part of the roll and then up elevator to exit the roll leveled. I think that using the rudder I can just get the roll done on lower speeds, yet to be tested.
Lookin sweet though, will look better in the airView attachment 141067 View attachment 141068 View attachment 141070 View attachment 141071 View attachment 141072 Almost there!
Awwwwww! Beautiful plane too!Update: she flew beautifully while she was in the air, retracts worked well, didn't change flight characteristics drastically, balance was perfect, but...I had a blackout. Don't know if it was the Rx or ESC, but after 2-3 minutes of flight, it lost all control and the motor went silent. When it dove to the ground the motor kicked back in and drove it hard straight down, didn't have time to recover. Don't know if I can straighten it all out again. May just use the parts to build Ver. 2. 🤕
I think you had a LOS or brown out issue, which is why the motor kicked back in at some point. That looks very much repairable to me, ask @Jimun .Update: she flew beautifully while she was in the air, retracts worked well, didn't change flight characteristics drastically, balance was perfect, but...I had a blackout. Don't know if it was the Rx or ESC, but after 2-3 minutes of flight, it lost all control and the motor went silent. When it dove to the ground the motor kicked back in and drove it hard straight down, didn't have time to recover. Don't know if I can straighten it all out again. May just use the parts to build Ver. 2. 🤕
Almost there!
It's a 40amp esc, and the retracts were not drawing anything when it happened. I have come to the conclusion that the ESC was overheating, since it was flying perfectly up to the point that it dropped from the sky. I had it tucked in the battery compartment without any ventilation. When I rebuild it, I'll put it outside the power pod.Depending on the amps for the BEC and with the added retract servos that could be your issue. You might have to run an external BEC that has 5 or more amp rating.
It's a 3A BECNo the BEC not ESC. Check what the amp rating is for the BEC.
