A few questions occured while building, maybe you could help me there sponz?
- when i add the 1/2" to the rear stab it would reach forward under the wing. Is this intended to give the wing a slight downwards angle or did I mess up the mesurements somewhere?
- in which angle did you mount the power-pod? so that the rear edge touches the inside top side of the fuselage? (I assume that the leading edge of the pod is meant to be right beneath the leading edge of the upper side of the fuse)
- I was thinking of attaching the wing with velcro (the strong selfadhesive blue HK stuff) Any thoughts, if this might hold up?
First of all, nice mods. Those should work well. Pretty similar to what Keegan did with his.
Question 1: It was only 1/4" that needed to be added??? Are you working from the latest plans? If so, I already added the 1/4" in the plans. If not then then just make the horizontal stab flush with the bottom plate of the wing.
Question 2: The rear of the power pod should touch the inside top of the fuselage. The C fold provides the thrust angle. You will want to position it front to back to accommodate your specific motor.
Question 3: Keegan's wing was held on with just two rubber bands. I think if you have some good Velcro it could probably work. If you try it report back and lets us all know how it works.
After getting frustrated with my Pun Jet being essentially unflyable I scrapped it and built a Baby Baron instead using the same electronics. I love how the build goes together. I printed the plans and had no problem figuring out how to construct it. The only minor issue I ran into is the rear servo doesn't mount flush with the foam board.
Haven't flown it yet, though.
ruud said:Maidened my Baby Baron this morning. I had just eyeballed my control throws and may have set them a bit too big, as it was somewhat twitchy even with 30% expo, but on the other hand the roll rate is just insane
Thanks SP0NZ for this awesome design and the clear plans!
tried to maiden mine yesterday, but 20 km/h winds with gusts up to 30km/h just were too much for the little one.
but at least i know now that it's a really durable plane. took next to no dage from the high speed vertical landing.
The horizontal stabilizer piece tucks right under the folded-over wing which is cool but leaves the hole for the servo right next to the upper wing half, which means the little tab of the servo (where the mounting hole goes) has no room and you either need to cut a little notch out of the wing or mount the servo a little crooked.Thanks for the great feedback on your build. Can you elaborate on the rear servo issue, perhaps post a picture?
