In doing the Speedster/SE5 mash up I have decided to make a larger scale biplane with the Baby Blender. I am inspired and love the look of these planes. I watched the review vids of the Baby Blender and I like the slow fly capabilities of this plane at the larger size. Due to the nature of my mod tendencies to planes I'm thinkin of tweekin it a bit. Here is what I'm thinkin:
1. Nose mod. From the build vid it looks like there is room between PP and the fuse sides to add doublers on both sides to beef up the crash damage a bit. Plus the FB plate that is glued to the bottom of the upper fuse of the top plate could be a C fold from the top plate tucked under to make this said plate to give the skewers a skin of paper to set in to. Then to give the fuse nose a slicker more profile look is to drop the height of the forward former above the nose by half. Gives a little downward profile. More racier nose to it.
2. Wings. I like how short in width the wings are but the straight leading edge may be a little old school for this guy. I was thinkin of doin a little bit of a swept wing design by a few degrees just to again give it a more racy profile as well. Even tho i'm thinkin of a slower plane it's also about looks and catching attention from other builders, and to step up my building game. I might build the straight wings to begin with and move forward if I need to rebuild them. Next thing is more of a question... Dihedral or no? Dihedral on both upper and lower or just the lower... or the top only. Maybe just the upper because of the ailerons on the lower wing? Maybe this will have more of a polyhedral effect just doing on wing in this fashion. Then just like the Speedster biplane I built to make the struts out of skewers for strength and durability instead of just FB. now I noticed on the build vid that Bix added skewers to the leading and tail edges of the struts over the FB but there are no cabanes to the fuse. I might do the same design as I used on the Speedster/SE5 Mini that I did recently to compensate. Which in turn comes to nose weight... I will have a 3s 2200mah in the PP to balance this out hopefully. In the Spitfire I built the battery sits a couple inches back from the motor mount to balance and has a much longer tail section so I think I have room for adjustment. All thoughts and suggestions are fully welcome. Thx
3. Tail Section. Looking at the complete build out just like the SE5 the tail looks short to me... and watching the review vid Bix does mention how the controllability of the plane is a happy accident as to how it isn't pitchy surprisingly. I don't know if I am totally convinced on that cuz it is a really short plane and it really shows it on the ground as to it's strong AOA. Just like on the Speedster/SE5 I built I might extend the tail out by 2-3 inches to make it more controllable.
If anyone has done these kind of mods to this sweet little plane and has seen results it is much appreciated to share because I'm doin this blind. I can use all the feedback out there you may have on this situation. My last 2 posts haven't seen any responses yet and really these are to reach out to learn on what I am doin so far and move forward. Thx for reading and keep it shiny side up.
