Almost done - my battery concerns were unfounded - by the time I loaded everything up to balance it, I had to practically shove the battery into the tail. No problems with the hatch at all back there. I'm only going to be able to use my thin 2s800 in this without adding some lead in the tail.
But everything stuffs in here nicely now. LemonRx receiver glued on the right side.
AUW including prop and battery is only 204g! Even when the battery is full the FAA shouldn't be a problem.
With a 2300kv 2204 and a 6x3 prop eCalc thinks I should be just fine. Thrust to weight is 1.64 and estimated level speed is 35mph. Should be able to take a 7x3 if it needs more gunt on 2s.
I should be able to get her into the air next weekend and see.
