Is it severely tail heavy, or is it almost balanced, If it is almost balanced using a bit of lead in the nose should help. If it is severely tail heavy, then perhaps a larger battery is needed. Plus, then you would get longer flight times. What size lipo are you using right now, and where is it placed. I think that info would help in figuring out what the problem is. Hope this helps.
