I know if you search for "balancing props", you'll get a ton of results. What you don't find is how to know the prop is balanced. I don't mean that it sits perfectly still in any position, I mean, what if your balancer itself is introducing an imbalance. I was re-balancing the props on the hex (again) to try to get rid of the always/still annoying jello in my video and I realized the shaft in my magnetic balancer was picking up magnetism and it wants to orient itself with the poles in the magnets! So I demagnetized the shaft and placed it back in position. POOF Instantly magnetized again! So, does anyone have any ideas? My Du-bro doesn't seem to have the precision of the Top Flight as in I can balance perfectly on the Du-bro then take it to the TF and it still shows a heavy tendancy, even if I spin the shaft to try to negate the magnetic problem. But now I know that my props are not balanced as well as I thought they were, as I can hear it in the video. I always wondered about it but thought it couldn't be the props since I always balance both blades and hub.
Help!
Help!
