Add me to the list. I’ll pick up a P-51 or Eaglet and get in on the action.
Add me to the list as well. It has been way too long since I built a balsa plane. It will be hard to wait for the new releases to make a decision on which one to start building though. 😉
Rob
Would one of these be a good plane for a first balsa build?
Nice, I think at $40 (with covering) I'm going to go with the GLH 250.They would be perfect for a first time kit!
Or for a newbie pilot? I.e., relatively slow-flying three-channel?
I have a clothes iron, didn't know that would work. Do you know of any threads that go over the basics of building with balsa as well as the basics on covering?I think these would be just fine as a first balsa kit - especially a GLH as that's the model the build videos are based on.
I think the GLH would be a terrible choice for a beginner pilot - but you should be just fine on that side!
A heat gun would be problematic for applying the covering. If you don't have a modeling iron in your future, a clothes iron (especially those small travel sized ones) would work fine too - just use a thermometer or test scraps of covering to keep an eye on the temperature.
If the heat gun is all you've got, I'd try using a heat activated / sensitive glue like https://sigmfg.com/collections/covering-paints-and-dopes/products/sig-stix-it-covering-adhesive to cover the bare balsa first, and then gently hit it with the heat gun to activate the adhesives and then pull the covering down. The combination of the adhesive already on the covering and the Stix-it already on the balsa will give you a much quicker and more secure connection at a lower temperature / pressure combo (that will be very hard to apply with the heat gun).
I'd recommend ordering an extra pack of covering for experimenting - remember you can always try putting it on the wing and then decide to heat it up with the gun and pull it off again!
I had a quick question about ordering the completion package and called the number on the website page. To my surprise Doug answered and I had a great discussion with him! Extremely helpful and gracious with the discount offer for this build. I placed my order and now I need to clean up the work shop to get ready for that soon to be here delivery!!!
Thanks again Doug!
Rob
Hi Joe, I ordered the GLH 250 with the completion package A. I have been building foam board for quite a few years and figured it worth while to support Doug and get the package with everything ( plus I needed the glue) 😁Which kit did you get? That completion package sounds like a great deal for the price.
Joe
