Guess we'll see how it holds up to the abuse of landing.
I guess it depends on your definition of a "landing". If it's nose first, full throttle from 30 feet up then the gear may be compromised. Most changes were made after seeing what I could break on the bench by hand with reasonable force. If using normal .031 micro push rod then it'll flex and cushion forces on the arm. From what I put the latest arm through I'd trust it up to .047 wire. The nose gear block has been strategically beefed up as well as I seriously doubt there will be room to mount normally on the front of the firewall. It'll likely have to mount on the back and all landing impacts will be directly applied to the lower pivot. If that breaks it's better than having it rip the firewall out though that hard of a landing will likely require repairs anyway. LOL.
I'm in no way an engineer and I don't have any clue what I'm doing so everything is just a W.A.G and each success is a total surprise.
Once I get the kit if I find the gear holds up I'll be happy to share the files. Heck, maybe there will be more room than I expect and I can enlarge and beef it up even more. I'm not doing this to market it. It's just a project to help me to learn to work with TinkerCad and finally put the 3D printer to better use. I'd love to work on a 3D printed main gear mount but I don't have any measurements to work from. Maybe I should have ordered TWO Eaglet kits so I'd have one sacrificial lamb to test my crazy ideas on before building a final version.
I.....need.....some......sleep.....
Joe
