balsa cut question
pisagor
Hi guys.How can i cut balsa like picture. I'm building a flying wing and i hate sanding elevons :D
Can you suggest me easiest way?
Ak Flyer
Fly the wings off
You can buy pre formed pieces for ailerons and things. Otherwise sanding is your best choice. I can never get a straight cut that long with the grain.
aiidanwings
If it is a large piece, use a fine saw to cut groves about every 1/8 inch or so from the thick side to the point. Then use a flat blade screw driver to gently break the tabs between the cuts. Finally, use a sanding block to finish the surface. 180 grit or finer should do.
If it's a small piece, use a hard backed sanding block or file to cut the taper.
Go slow either way.
