Update:
Fitted motor and ESC to power pod fitted to Fuselage.
Fitted Rx and connected servos and ESC. Powered up, and bound RX. Checked motor rotation. Cantered the servos and fitted servo arms.
Fitted servo cover plates made from paperless FB and covered wing tip underpanels.
Made up temporary undercarriage for taxi trials and maiden flights.
Weighed plane, Total Weight, (Excluding Battery), 567 Grams!
Checked CG with a battery and NO extra weight required.:applause:
Now just a few trim details and the Maiden! Weather here is poor at the moment so I will advise of when Maiden has occured and what the result was.
A few progress pics:
Servo cover plate
Wing tip covered underneath.
Both sides.
Motor and power pod fitted , (with spinner).
Temporary landing gear fitted.
From memory my son's Spit required a considerable of nose lead and weighed in about 683 grams and with his landing gear the weight went up to 754 Grams, (measured without the battery). Mine weighed in at 567 Grams and 580 with Undercarriage, (again without battery). A saving in weight of 116 grams because of the lightening and the lack of a need for balancing lead.
It looks like the 4S battery will definitely give unlimited Verticals.
Will remeasure the weight with flight battery later after the maiden, and I am trying to have my son's Spit returned for a all up flying weight as well.
More Later I hope!
