Ryan O.
Out of Foam Board!
I am in the process of building a swizzle stick from Balsa USA. At Warbirds Over Wisconsin Joe from Balsa USA have this to me to build and post my progress. Instead of the Nyrod wing setup with one standard servo I weng with two external 9grams which are easier to service. This is easy so far I just need help to cut the reliefs for the glow engine. The razor saw wasn't able to cut through and I think I will find someone with a scroll saw. It will be a "search and rescue" aircraft for the field because it is a perfect camera platform. I will use yellow monokote amd red ultracote srtipe. The other servos will be staandard size metal gear. (I probably should have posted this in the balsa section, whoops)
