Moved some more to the "getting repaired" section...
-FT Spitfire update... had to shift some things around PLUS add a few small weights to help with balance issues. Still need to add a servo extension to one of the servo wires due to having to move things. After that, I can charge up a battery and go maiden it.
-Shrubsmacker update... most of the electronics are done minus the receiver. All linkages done and plane is about 95% built...just need to add front hatch and LG.
-Seaduck - wing reinforce repairs are done. I need to fix hole in wing and repaint. Then reattach bottom part of fuse and balance plane. Add additional weight/spray foam if need be for balancing.
-Mystery Ship - begun looking at CAD programs and working with plans to print out.
-KFM Wing - moved all electronics to center, repaired firewall. Need to add skid and check balance again.
