Hello all,
I'm trying out the FT bat bone tri 370 and I have a few questions about the build. I'm not sure if there is another forum on here that I can refer to so I'll just go ahead and ask my question until I hear otherwise.
1. Where is good place mount the KK2.0 board on the Bat Bone Frame? How do you mount it?
2. I am using these motors and I believe FT suggests a motor that is a couple of grams lighter why, and will I have problems?
3. Many people are using SimonK flashed ESCs, but I'm going to use these. Is there a problem with what I'm using?
4. Is there anything special that I have to do with my ESCs prior to flying(ie remove the positive lead from the molex connector, or hook up a programming card to them to change the programming)?
Thank you,
NAVET97
Thank you,
NAVET97
