Help! Battery charger suggestion
Sean2448
hello everyone my name is Sean and I am 53 and after nearly 20 years of non flying R/C planes I’m getting back into it but since then it seems a lot has changed. First off I had to buy a radio (spectrum (Nx10) since my old futaba doesn’t seem to work with today’s technology. I am looking to buy the tms 1800 mm ranger but I am open to other suggestions. This is where I need help…
I know they will recommend what battery and recover to use but I would like to get the best battery for flight time and a battery charger that will charge Quick. Maybe even multiple batteries at once and a speed control to handle the load. I am aware that it will cost more but you get what you pay for sometimes also a good 6 channel receiver. Thanks in advance
Quick charging lithium polymer batteries makes them warmer than ambient. Quick discharge during a flight takes that warm battery and makes it hotter. Not good juju. Don't have the heat problem as bad with NICADS, but flights were 3 minutes only on my Aeroflight stuff
Speed control won't help, best case just slows charge process down and gets hot itself. A half dozen charged batteries quick swapped can last many hours. Pop off the hatch, pull the connector, pop a fresh one in, plug it in, go fly. Repeat until you need a bathroom really bad. I'm old, too. Really want to loiter, you want gliders: battery lasts 4-5 hours if there's enough lift
My futaba stuff is from 1975-76(?) Still use it, can buy AM receivers last I looked, but YMMV. Sorry doesn't have settings for other models, no mixers or servo reverse. Mmm mixers, no twitchy vector directors needed for flying wings and you get to do flaperons.
...the best battery for flight time and a battery charger that will charge Quick...
The first thing you need to know is concept of C, that is how fast can you charge or discharge a battery. 1C is the milli amp hour capacity of the battery divided by 1,000. To calculate how many amps that can be drawn out of a battery take the milli amp hour divide by 1,000 times the C rating (mah/1,000 x C). Example a 2,200 mah, 25 C, battery can supply 55 amps (2,200/1,000 x 25 = 55). As far as flight time, more mah equals longer flight time, up to a point. At some point the additional weight of a bigger battery will cost you flight time. That is if a 2,200 mah battery gives 10 minutes of flight. a 4,400 mah battery may only give 15 minutes.
To prolong the life of my batteries, I charge at at 1 C. I usually get 3 years of so from a battery before is is retired. The size of your battery should dictate the charger you consider. I use 2,200 mah batteries and the IMAX B6 is a good match for me. I can charge a battery in about an hour. But the B6 would take far too long to charge a 6,600 mah battery, it just cannot put out enough amps.
I don't like to wait on batteries to charge, the B6 is cheap enough I can afford to own multiples. I prefer this to a much higher price multi channel charger. With the multi channel charger, when one channel goes bad you are stuck. When one of my eight B6's goes bad, I chuck it and replace it.
Rather than charge each battery quickly, I charge many batteries slowly.
Foamforce
I’m happy with my Hota F6. It’s the DC only variety for $80 on Ali. It’s small, has four ports, and you plug the balance lead and the main lead (XT60) directly into the unit without extra leads. That makes it a lot more compact for me to bring to the field. Just the charger, a source battery (or your car battery), and a single wire to connect the two. I fly with my two boys so we charge a lot of batteries at the field. 🙂
HVB79
You could buy a IMAX B6 (or re-branded copy) and get 2006 technology or for the same price buy a much more capable 200 watt charger with a better screen and better user interface.
Example: iSDT Q6 Nano
If you already own a fleet of eight B6 chargers I can see why you would buy a B6 replacement to keep everything consistent. But otherwise, I don't know why you would buy a B6 instead of one of the many better modern options.
Bricks
It comes down to time, how long do you want to wait to recharge a battery? My Hyperion Duo 2 will charge a 2200 battery in about 20 minutes or charge at 2C and even faster. I can charge up to 12 batteries at the same time with a balance boards.
