Battery Charger Wall Charging Plug
baronbernie
Purchased a battery charger from HK and was suprised to find that the wall plug was not going to work. The prongs on the plug were round and farther apart than the regular plug. So it must be from overseas. Is it possible to change the plug to the type that will work here in the U.S.?
Johan
Changing the plug might no be a big problem, but be careful with the expected input voltage.
It sounds like a european plug, we use 220 Volts instead of 110V. So check the required input voltage first.
A lot of devices can use both (autoswitching or sometimes requiring a manual switch).
There are also chargers that require an external power supply (12-18V) like this one:
http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=7028 (Turnigy Accucel-6 50W 6A Balancer/Charger) but those usually come with other plugs of course.
eagle4
i have a charger that has a UK plug, i just use a plug adaptor you can get from any electrical store and it works fine
Tritium
Amateur Extra Class K5TWM
Use some well insulated female bullet connectors on a standard 2 wire cord. Be careful.
Thurmond
xuzme720
Dedicated foam bender
I just bought one of those and it doesn't come with the 12v supply. HK does have one for this charger, but I'm not sure it would work with yours as a plug-n-play. http://www.hobbyking.com/hobbyking/store/uh_viewItem.asp?idProduct=36904
Tritium
baron just chop off the plug and put on one that fits, easily obtained at a big box store. Very easy to do.
Thurmond
xuzme720
You should be able to get yourself an adapter plug for round post European to flat blade American with no issues. Input on the charger is listed at 100 to 220v so should handle our outlets fine.
baronbernie
This morning I made my way to the somewhat nearest Radio Shack store with the charger at my side. Talked to the sales person and explained my need for a different electrical plug for the charger. In no time flat he walked over to one of the displays and came back with a plug that could be used for our outlets. Yooo Whooo, hi ho hi ho it off to the field I go!!!!!
