AviateCrate
Does anyone know a good way to wire up a battery voltage sensor? I have a new ELRS receiver that comes with a sensor wire. I built a short extension with XT30 connectors on each side and soldered the sensor wire to the positive side.
This is connected between the battery and the ESC. It works, but it seems heavier than it needs to be. (Please excuse the lousy soldering, and I did apply the heat shrink before connecting a real battery.)
My other thought was to solder the sensor wire directly to the ESC, but I’m not sure my soldering skills are up to it. If I do that, then the sensor wire must stay with the ESC, so I can’t move it with the receiver to a different plane.
Or, I could connect to the battery balance plug. That would be more flexible, but it requires connecting two cables every time I change a battery.
Any other suggestions? Thanks!
