Bavarian_RC
As promised a little update on the Me-410.
During the build of the V1 fuselage and also during the first flights it was getting more and more clear that I had to do a major re-design of the fuselage.
The main objectives were:
So here we go: Fuselage V2!
The inner structure of the rear part is quite similar to V1, just added some lightening holes in the middle sheet and made the spine a little longer to support the horizontal stabilizer. The forming of the rear skin is quite tricky due to the tight radius on the bottom. Maybe I will try to split it next time into a forward and rear part.
The horizontal stabilizer now has a BBQ skewer on the leading edge and the paper wraps around to give it a clean look.
The forward fuselage structure with the pieces for the wing attachment and the formers:
Installing the skins on the fuselage front part. The nose was the most difficult part and I think I made in total 5 or 6 versions until everything was fitting and I had found a repeatable process for getting this good fit.
In the next post I will show you the progress I made on the canopy hatch. But that’ll have to wait for another day…
- Reduce weight
- Position the battery further back (I needed a lot of balance weight in the tail of V1)
- Replace the slide-on nose cover by a canopy hatch
- Improve the design of the canopy
- Make some small improvements on the wing attachment
- Improve the horizontal stabilizer
