If by wires you mean the shaft going from the retractor module to the wheel, there are options out there on Banggood and Hobbyking for different shafts HOWEVER they are for retractor modules designed around having separate shaft pieces fitted. Have a look at your system and see if the shaft is detachable.
If your retractable gear and shaft is all one piece then your only option is to see if you can replace the wheel on it with a bigger one and get an extra inch or two that way. If not, well, a short gear is probably still better than belly landing it. Just means you’ll have to launch it by hand or catapult rather than taking off from the ground.
