I have a question - when you have more than one heli setup w dx6e, do you have to rebind when you switch between them? I can’t seem to get the remote to switch back and forth w each heli. What am I missing?
No you should not need to rebind when switching models. I agree with @ElectriSean, be sure you power up the Tx first, select the correct model, then power up the model.
Be sure each Rx has been bound to the Tx. When bound, the Rx will work with any model in the Tx you bound it to. You will need to rebind if want to use the Rx with a different Tx.
