leaded50
A few in here made posts but seems never make any completed build of the plane. I was awaiting for someone do it, and not steal their idea. Well now its at least a year ago since last posts...
I will build this fantastic great looking airplane racer design! With functionality!
Well, this was a idea for Bell % Ross wathcompany to build by design from a guy. Yes, he was an engineer, but not any machine engineer, or any aircraft engineer. He was just a plain design engineer.. Thats quite easy to find out too, beause that plane if build as it, would NOT been flying, it would just be a mostly uncontrollable lawn dart!
As a start, the stabilizers movable parts would be too small vs the quite wide root of wing. , the rudder also too small, and worst possible? The wing has a negative incident, thats it would be hard create lift... shurely when the stabilizer has a good positive incident .
aka a LAWN DART!
NO, the plane was never buildt! It just dangled around as a designproposal on paper!
This all needs to be reworked, and it will also at least affect the trailing edge of wing to the rear (or cockpit)., to not get a leadingedge to fuselage part that will be as a stationary "upangled" spoiler.
Im awaiting more foamboards to come here, and in the time awaiting , i will try get the best fixes in scetches to my mind
before start building.
I found i had a 5 - blade prop laying around, and a swiss motor with for sure enough power . this is more for alike scalebuild, than speed perhaps. Well the prop can easy be changed anyway! It seems difficult get a reasonable priced prop a touch bigger than what i have, so will make it in scale measures out from that.The propdiameter, and the airplanes measures is not found in infos, but by measure the prop i have, and sizing pictures against it, and then adjust sizing of whole plane , it shows the total length/wingspan. This will give approx 1015mm length, 965mm wingspan. I was thinking of a approx 1500m long build, but $300 + freight, just for a 5-blade prop to the fit that size scale, isnt worth the extra mm´s.
Here is a pic of the nice designbird.
