Best Dollar Tree foam board cutting tool!
Like I said, I just do it in a well ventilated area.
It does smell quite strongly. I hadn't done to much cutting when I first started the thread but I have quite a bit now and I recommend having a open window on one side of the room you are cutting in and have a window fan in the window next to you. I use a heater as my intake in the winter:)
AIRFORGE
Make It Fly!
Opening a window is not adequate ventilation. You need vacuum dust collection. Preferably with a filter. I use a simple modified wet/dry shop vac with a HEPA filter. You can get an appropriate dust mask if you are unable to get a dust collection setup but there will be more to clean up after cutting.
There is no dust, it just melts through. Just a somewhat strong smell.
So yeah,it looks like its fine to cut foam board with a hot knife but you should use proper safety measures. It wouldn't make sense that you couldn't cut foam board at all with a hot knife because they sell tools all over amazon for cutting foam. I really like how much better it cuts than a regular razor! I don't think I could have had such clean cuts on my P - 38 if I didn't use it. Here is what google AI compiled as far as the safety of cutting foam board with a hot knife
While cutting Adams foam board with a hot knife isn't inherently "toxic," it can produce fumes that are considered harmful if inhaled, so it's important to always work in a well-ventilated area and wear a mask when cutting large amounts of foam with a hot knife; check the specific foam board manufacturer's safety guidelines for the best practices.
Key points to remember:
  • Fumes from heated foam:
    When a hot knife melts the foam, it releases small particles and fumes that can irritate your respiratory system, especially if not properly ventilated.
  • Check the foam type:
    Different types of foam may produce different levels of fumes, so always check the manufacturer's instructions for the specific foam board you're using.
  • Safety measures:
    • Ventilation: Always work in a well-ventilated area, ideally outdoors or with a fan directed away from you.
  • Mask: Wear a respirator or dust mask to filter out the particles.
  • Safety measures:
Yep, that all agrees with my opinions.
AIRFORGE
Make It Fly!
  • Safety measures:
As I said.
AIRFORGE
Make It Fly!
I think the main takeaway here is for us to be careful. Especially if we do this repeatedly. I've been CNC cutting carbon fiber, plastics, wood, foam board, etc., for a long time. I always have a vacuum running for the foam and use the vacuum and a mask when cutting and cleaning carbon. (y)
Agreed.👍 The strong point of using the hot knife is when doing detail. For straight lines I like to use a ruler or for big things a 4' T square with a good sharp razor. but for all the detailing I like using the hot knife.
