PsyBorg
Wake up! Time to fly!
I usually just take some of the foam from one of the Emax motor cases and custom cut it to suit the camera. Here is the mock up of what I was using when I had a Runcam mini mounted. I will cut a little deeper and a little lower to mount the micro on this one. Then all I do is run a piece of double sided tape on the back side of the camera to pad it on the upper plate and then wrap thin strip of Velcro around the upper part of the camera around behind the front posts to keep it tight against the upper plate. The VTX will mount on the top part of the upper plate as the receiver is mounted to the under side of the upper plate.
I may have to cut a new piece of foam as there is not much side stability on the existing one.
