jonmichael145
whats the best/strongest glue for wooden planes. any help would be greatly appreciated.
Thick CA is used for most non structural parts, wood glue is light, and a little more flexible. It can be used for parts that have a large surface area, like for example laminating two pieces of balsa together, but it takes a day to cure to full strength. My favorite adhesive is epoxy. It is incredibly strong, and comes in different types, from 5-minute to 24 hour epoxy. The longer it takes to cure, the stronger the bond will be. 30 minute epoxy will be good for almost everything there is, but say you are gluing together a crucial piece, 1 hour to 24 hour epoxy will hold on tight and the wood will break before the glue joint. I've also found that if you want to keep parts aligned, and they aren't the easiest to clamp together, a few drops of low temp hot glue will do the trick. The glue is then removed after curing.whats the best/strongest glue for wooden planes. any help would be greatly appreciated.
thank youIt absolutely depends on what you're trying to glue. The "strongest" is often the heaviest, and therefore not "best" for every application.
On a single plane I can use thin CA, medium CA, Titebond II, 30 minute epoxy, and canopy glue. Each glue has it's pros and cons, it's up to you to decide which glue to use as you build, and I recommend you try a few to find what works best for you.
thank you!!!It depends on the application, I use plan white glue for the majority of the balsa build. I'll use epoxy for high stress areas, wing joint, firewall etc. CA for places I want a quick set then follow up with a white glue filet for more strength. I prefer to use a syringe to apply the white glue. This will keep the weight down by using the least amount of glue posible.
thank you!!Thick CA is used for most non structural parts, wood glue is light, and a little more flexible. It can be used for parts that have a large surface area, like for example laminating two pieces of balsa together, but it takes a day to cure to full strength. My favorite adhesive is epoxy. It is incredibly strong, and comes in different types, from 5-minute to 24 hour epoxy. The longer it takes to cure, the stronger the bond will be. 30 minute epoxy will be good for almost everything there is, but say you are gluing together a crucial piece, 1 hour to 24 hour epoxy will hold on tight and the wood will break before the glue joint. I've also found that if you want to keep parts aligned, and they aren't the easiest to clamp together, a few drops of low temp hot glue will do the trick. The glue is then removed after curing.
If you are getting into balsa building here is the list of glues you will need to get (some are used less often than others):
Thick CA (best for use on balsa)
Medium CA (sometimes used on Balsa, but rarely by itself)
Thin CA (more for plywood since it seeps into balsa wood, but is used for sealing laminated pieces of wood)
Wood Glue
Canopy Glue (used to glue plastics, like the canopy... of course
Thread lock (used for the screws for landing gear and motor mounts)
Epoxy (strongest one I like to use)
CA Gel (not as strong as epoxy, but is a good substitute on smaller models. It is essentially really thick CA)
I hope this answers your question
These answers reflect what a civilized bunch we have around here. It's like asking what's the best oil for your car. Everybody is pretty much on the same page here. I build small, lightweight balsa airplanes in the 8 ounce or less range so I use thin CA glue 98% of the time. The other 2% of the time epoxy or Titebond is right for a special purpose. Once in a while I might even use a drop of hot glue.
I agree wholeheartedly. You must use the right glue for the job. I'd never use CA for an airplane weighing 8 pounds. It's too brittle and doesn't fill gaps. The biggest airplane I ever assembled was the 2M Apollo sailplane. I not sure if I used any CA glue. Most of that was glued together with 30 minute epoxy. It weighs 3.5 pounds.And I'm at the other end of the spectrum and use CA 2% of the time. Most of my gluing is done with Titebond II, but my planes are usually 8 pounds or more.
Anyone tried Super Phatic? My understanding is that it's an aliphatic glue, but is low viscosity so it would be better suited for the modern laser cut kits.
are gloves enough generally to use these glues/epoxy?SIG Super Weld, Titebond, and Superphatic are my go-to glues. I love CA and epoxy, but years of using them while disregarding safety measures has caused severe allergies to them. If I need CA or Epoxy, it requires long sleeves, gloves and respirator. No fun building like that ;-)
Refrigerating CA works well as long as it hasn't been opened.One thing to note is don't buy a bunch of glue then let it sit for a year, just buy it as you need it because it works so much better when glue is fresh, especially CA. Titebind doesnt seem to care, but some glues do not like sitting on the shelf for years.
Not sure my wife would like my hobby stuff in the fridge, I can barely keep a few beers in there now...lol
