Best KV for a prop size chart
quorneng
It is perhaps worth pointing out that kV does not describe the power of a motor but simply the speed it rotates for a given voltage.
You can have two motors with the same kV but that generate completely different levels of power from the same voltage. Both motors would rotate at the same rpm but the props for each would be very different.
