I am slowly building my FT Bronco and I realized that the recommended specs list a 8" prop. Looking at the build I suspect I won't have clearance for 9" props but I don't have two 8" props in both CW and CCW. I was planning on running my Bronco on two 4S 100C 1500mah with two C-pack motors (emax or radial, not sure yet) in parallel so I should have plenty of power but I struggled to find many 8" props. Most stores only had CW or CCW. I found a one or two 7" 3-blade props from 3" to 5.6" for quads, so I would get a set with both directions. For example https://www.getfpv.com/dal-cyclone-t7056c-pro-propellers-set-of-4-crystal-clear.html .
What does everyone use for props on the bronco? I would be happy with recommendations for either high thrust or maximum speed. I was hoping to use my Bronco for a rubber duck bombing platform but if it happens to wind up fast instead, I won't complain.
