I went with merv's suggestion and have all the components metioned in the video minim osd,gps,programmer .(Very Cheap)
i downloaded the arduino ide and edit the MW_OSD.ino file ,save it ,verify it just like in the video but when i plug the usb in from the programmer that is connected to the micro minim osd i get device did not install correctly and when i install the drivers in the driver file that comes with arduino isd i plug in again select the new com port try to upload to the minim and get this ...........
Sketch uses 19372 bytes (63%) of program storage space. Maximum is 30720 bytes.
Global variables use 1850 bytes (90%) of dynamic memory, leaving 198 bytes for local variables. Maximum is 2048 bytes.
Low memory available, stability problems may occur.
avrdude: stk500_recv(): programmer is not responding
avrdude: stk500_getsync() attempt 1 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 2 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 3 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 4 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 5 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 6 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 7 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 8 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 9 of 10: not in sync: resp=0x86
avrdude: stk500_getsync() attempt 10 of 10: not in sync: resp=0x86
Problem uploading to board. See
http://www.arduino.cc/en/Guide/Troubleshooting#upload for suggestions.
*NOTE Programmer has red light , Minim osd has Blue light with flashing green (Blinks bright green a few times when i plug the usb in and Bright a few times when i try to flash.
Anyone in the know have any thoughts on what i might be doing wrong ?
