A better (more visible) parachute drop from my SAR Guinea Pig this time! Peter
Homey Elite member Aug 24, 2019 #1 A better (more visible) parachute drop from my SAR Guinea Pig this time! Peter Last edited: Aug 25, 2019
24wolffky New member Oct 9, 2019 #2 cool I built a guinea pig also with gear,flaps,steerable nose wheel and the bomb drop
mayan Legendary member Oct 16, 2019 #7 Droping stuff from the plane is so fun , too bad you have to reload after on around .
24wolffky New member Oct 16, 2019 #8 yah I made it so I have 5 drops for every servo then it lasts longer if you edit the rate
mayan Legendary member Oct 16, 2019 #9 24wolffky said: yah I made it so I have 5 drops for every servo then it lasts longer if you edit the rate Click to expand... How did you do it ?!
24wolffky New member Oct 16, 2019 #10 hook the servo up to the switch on your transmitter with the 3 modes and have a really long servo wire
mayan Legendary member Oct 17, 2019 #11 24wolffky said: hook the servo up to the switch on your transmitter with the 3 modes and have a really long servo wire Click to expand... Do you have a picture of it?
24wolffky New member Oct 17, 2019 #14 this isn't my video but it is the same thing i did but i did it with longer wire
mayan Legendary member Oct 17, 2019 #16 24wolffky said: Click to expand... Thanks a million! That’s how I have it setup still can’t picture how did 3 drop with one servo. Or I might have missed something but I have an idea not sure how it will work though. Last edited: Oct 17, 2019
Wildthing Legendary member Oct 17, 2019 #18 I did one with a 2 drop setup. Servo neutral both locked in, full left one drops and full right the second one drops.
Wildthing Legendary member Oct 17, 2019 #20 24wolffky said: Is it 3d printed? Click to expand... Yes, but if you don't have a 3D printer with a little ingenuity you could make it out of anything.
