This is a 10 to 1 scale model. Wing span is 39 inches. Its not exactly to scale. I did take some liberties as I was going along. The reason why I built the F version is so I can convert it to an E version. By clipping off the wing tips and adding supports to the vertical stabilizer you're pretty much making the E-3. Granite, along with the classic yellow nose it will look really good. The body will be wrapped with poster board. It is really flimsy as of right now, but I have a model before this that I had already wrapped and it makes it so much stronger. I can grab the nose and swing it around without any problems.
So the prop is a 10" from the C- pack. When I finish the build and know that it flies I will paint it and buy a new 3 bladed prop off of master airscrew to complete the look.
Still need to test the landing gear but I'm confident that it will work. I just don't know for how long
. My landing gear system will be a work in progress while I work on more airplanes.
(Now that I look at the picture it might have been warped or just the angle of the picture, but the wing is scale to fuselage. Off the top of my head I think its 32 inches.)
